Philco 38-690 electronics restoration.
#35
Mike
Before you go much further on your 38-690, you might want to read this:
http://www.philcoradio.com/phorum/showth...?tid=14968
I would replace that 1 uF tweeter cap with a 4.7 uF polyester cap. Also check the tweeter wiring as indicated in the link above. You will thank me later. Icon_smile
Regarding the 1.75 - 1.75 uF cap: I'm afraid I have no clue on that. I might hazard a guess and say that perhaps this was a World War II replacement when parts were scarce and repairmen were limited on what they could use for replacements? Again, that is just a guess.
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by Ron Ramirez - 05-07-2017, 08:41 AM
The speaker table error?
Philco 70 antenna lead
There are currently 2109 online users. [Complete List]
» 2 Member(s) | 2107 Guest(s)
