what to do next
+70v or -70v? If you are using an analog meter( one with a needle) you with have to reverse the leads to measure any negative voltage. Digital meter there will be a small minus sign in front of the number you are reading.
what to do next - by denver - 01-15-2010, 04:22 PM
Re: what to do next - by Carl Travis - 01-15-2010, 04:50 PM
Re: what to do next - by denver - 01-15-2010, 07:06 PM
Re: what to do next - by 7estatdef - 01-15-2010, 07:23 PM
Re: what to do next - by denver - 01-15-2010, 08:24 PM
Re: what to do next - by denver - 01-16-2010, 12:40 PM
Re: what to do next - by 7estatdef - 01-16-2010, 02:39 PM
Re: what to do next - by denver - 01-16-2010, 02:56 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:00 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:06 PM
Re: what to do next - by denver - 01-16-2010, 03:34 PM
Re: what to do next - by denver - 01-16-2010, 04:20 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:27 PM
Re: what to do next - by denver - 01-16-2010, 07:48 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:50 PM
Re: what to do next - by 7estatdef - 01-16-2010, 08:04 PM
Re: what to do next - by denver - 01-16-2010, 11:22 PM
Re: what to do next - by denver - 01-16-2010, 11:30 PM
Re: what to do next - by 7estatdef - 01-17-2010, 08:47 AM
Re: what to do next - by denver - 01-18-2010, 10:41 AM
Re: what to do next - by 7estatdef - 01-18-2010, 01:39 PM
Re: what to do next - by denver - 01-18-2010, 03:26 PM
Re: what to do next - by denver - 01-18-2010, 04:31 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:01 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:33 PM
Re: what to do next - by denver - 01-18-2010, 06:42 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:58 PM
Re: what to do next - by denver - 01-18-2010, 07:17 PM
Re: what to do next - by 7estatdef - 01-18-2010, 08:59 PM
Re: what to do next - by denver - 01-18-2010, 10:44 PM
Re: what to do next - by 7estatdef - 01-19-2010, 08:18 AM
Re: what to do next - by denver - 01-19-2010, 11:26 AM
Re: what to do next - by 7estatdef - 01-19-2010, 06:34 PM
Re: what to do next - by denver - 01-19-2010, 09:51 PM
Re: what to do next - by denver - 01-20-2010, 04:43 PM
Re: what to do next - by 7estatdef - 01-20-2010, 08:57 PM
Re: what to do next - by denver - 01-20-2010, 09:20 PM
Re: what to do next - by 7estatdef - 01-20-2010, 10:16 PM
Re: what to do next - by denver - 01-21-2010, 01:59 PM
Re: what to do next - by 7estatdef - 01-21-2010, 06:21 PM
Re: what to do next - by denver - 01-21-2010, 07:46 PM
Re: what to do next - by 7estatdef - 01-30-2010, 08:40 AM
Re: what to do next - by denver - 01-30-2010, 04:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
