what to do next
#33
I took a pic of a real 5 pin tube and number the pins for you. This should you a little better idea of how to count them. I'm very patient I just hope don't have as many posts as Ron's total before where done with this set . If you were on pin 2 the voltage is a little low should be about +35V. Check resistors #44, 500K, # 46, 250K & #51, 25K for proper value. While I was drive around today I had a thought,it doesn't happen often but tell me what is the resistance from the antenna connection the chaiss. You may have an open winding on the antenna coil, It's common of early Philco's
what to do next - by denver - 01-15-2010, 04:22 PM
Re: what to do next - by Carl Travis - 01-15-2010, 04:50 PM
Re: what to do next - by denver - 01-15-2010, 07:06 PM
Re: what to do next - by 7estatdef - 01-15-2010, 07:23 PM
Re: what to do next - by denver - 01-15-2010, 08:24 PM
Re: what to do next - by denver - 01-16-2010, 12:40 PM
Re: what to do next - by 7estatdef - 01-16-2010, 02:39 PM
Re: what to do next - by denver - 01-16-2010, 02:56 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:00 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:06 PM
Re: what to do next - by denver - 01-16-2010, 03:34 PM
Re: what to do next - by denver - 01-16-2010, 04:20 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:27 PM
Re: what to do next - by denver - 01-16-2010, 07:48 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:50 PM
Re: what to do next - by 7estatdef - 01-16-2010, 08:04 PM
Re: what to do next - by denver - 01-16-2010, 11:22 PM
Re: what to do next - by denver - 01-16-2010, 11:30 PM
Re: what to do next - by 7estatdef - 01-17-2010, 08:47 AM
Re: what to do next - by denver - 01-18-2010, 10:41 AM
Re: what to do next - by 7estatdef - 01-18-2010, 01:39 PM
Re: what to do next - by denver - 01-18-2010, 03:26 PM
Re: what to do next - by denver - 01-18-2010, 04:31 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:01 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:33 PM
Re: what to do next - by denver - 01-18-2010, 06:42 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:58 PM
Re: what to do next - by denver - 01-18-2010, 07:17 PM
Re: what to do next - by 7estatdef - 01-18-2010, 08:59 PM
Re: what to do next - by denver - 01-18-2010, 10:44 PM
Re: what to do next - by 7estatdef - 01-19-2010, 08:18 AM
Re: what to do next - by denver - 01-19-2010, 11:26 AM
Re: what to do next - by 7estatdef - 01-19-2010, 06:34 PM
Re: what to do next - by denver - 01-19-2010, 09:51 PM
Re: what to do next - by denver - 01-20-2010, 04:43 PM
Re: what to do next - by 7estatdef - 01-20-2010, 08:57 PM
Re: what to do next - by denver - 01-20-2010, 09:20 PM
Re: what to do next - by 7estatdef - 01-20-2010, 10:16 PM
Re: what to do next - by denver - 01-21-2010, 01:59 PM
Re: what to do next - by 7estatdef - 01-21-2010, 06:21 PM
Re: what to do next - by denver - 01-21-2010, 07:46 PM
Re: what to do next - by 7estatdef - 01-30-2010, 08:40 AM
Re: what to do next - by denver - 01-30-2010, 04:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
