Threads: 569
Speaker unplugged....always a bad idea if tested with rectifier in. Never ever do that again (and yes it is the same as having your field open).
Although in 20s case it is not as bad, in some others it could be really bad.
Speaker should be in, and the integrity of output xfmr and the field coil should be confirmed first.
So should be confirmed the absence of shorts across the filaments and B+ voltage lest your radio goes up in smoke.
And.....before following some guy on youtube, you are better off asking here. At least we will try to make you understand your actions and the possible consequences; youtube won't do it.
RE: Philco Model 20 Lowboy - by morzh - 05-13-2017, 06:44 PM
Users browsing this thread: 30 Guest(s)
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 4970 online users. [Complete List] » 2 Member(s) | 4968 Guest(s)
