Threads: 20
City: Orland Park
State, Province, Country: Illiinois
Ok, I officially don't know what I'm doing then. I had all of the tubes removed when I did this. It sounds like the video was useless. I pulled all tubes, set the negative probe under the chassis to ground and used the hot (red) to test each socket.
How do I perform a proper plate voltage test? Do I insert all tubes except for the socket I'm testing?
EDIT: I now have a tube tester but I had to order a new NE-51 lamp for it.
Greg
(This post was last modified: 05-13-2017, 07:12 PM by WallaceRoger.)
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-13-2017, 07:01 PM
Users browsing this thread: 21 Guest(s)
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 4164 online users. [Complete List] » 2 Member(s) | 4162 Guest(s)
