Philco Model 20 Lowboy
#44
OK, here's my progress so far, and thank you for the help.
1:
* Field coil: I did what Terry suggested earlier in the thread and I get 240 ohm and 210 ohm for the first couple pins, the third pin gave 3,230 ohm)
* Part #27 Choke: 436 ohm
Since they weren't zero, I'm guessing continuity is ok (not sure about the one higher reading)?
2:
* Tested output transformer. One side gives me a zero (the one that connects to the 71A closest to the antenna terminal), which means it's open? What's a good replacement part for this?
I stopped at this point. Need some clarification so I don't kill myself.
4: Leave all other tubes (except 80) in for this? Which pins do I use for the filament test (the two larger, the two smaller, one of each, or doesn't matter)? And how do I know which pins are 1,2,3,4 (start bottom right and counterclockwise to bottom left)?
5: Need to know which pins to use for filament test (or if it doesn't matter)
6: Hmm, so I'll use the chassis for ground and which of the pins do I check for the plate voltage? (Is there a handy diagram someplace that shows which is which for various tubes? I do a lot of referring back to reference materials while I'm working).
7: This is done at the power supply? Which point?
8: Since tubes are left in, I'll do this from the underside, correct?
The speaker cord does have some of the wire shroud rubbed off where it was pushed against a wall for many years. Before I do anything else I'll fix that issue.
Greg
Philco Model 20 Lowboy - by WallaceRoger - 02-23-2017, 05:14 PM
RE: Philco Model 20 Lowboy - by morzh - 02-23-2017, 05:44 PM
RE: Philco Model 20 Lowboy - by KCMike - 02-23-2017, 05:48 PM
RE: Philco Model 20 Lowboy - by klondike98 - 02-23-2017, 05:48 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 02-23-2017, 06:05 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 02-23-2017, 07:36 PM
RE: Philco Model 20 Lowboy - by morzh - 02-23-2017, 11:54 PM
RE: Philco Model 20 Lowboy - by David - 02-24-2017, 08:16 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 03-23-2017, 03:40 PM
RE: Philco Model 20 Lowboy - by Steve Davis - 03-23-2017, 06:10 PM
RE: Philco Model 20 Lowboy - by morzh - 03-23-2017, 06:14 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 03-23-2017, 10:46 PM
RE: Philco Model 20 Lowboy - by Arran - 03-24-2017, 12:13 AM
RE: Philco Model 20 Lowboy - by morzh - 03-24-2017, 08:52 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 03-24-2017, 10:47 AM
RE: Philco Model 20 Lowboy - by morzh - 03-24-2017, 10:51 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-16-2017, 05:03 PM
RE: Philco Model 20 Lowboy - by GarySP - 04-16-2017, 08:34 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-16-2017, 09:07 PM
RE: Philco Model 20 Lowboy - by morzh - 04-16-2017, 09:28 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-18-2017, 02:10 PM
RE: Philco Model 20 Lowboy - by morzh - 04-18-2017, 02:24 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-18-2017, 04:46 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-29-2017, 08:13 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 04-29-2017, 08:33 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-05-2017, 08:12 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-05-2017, 09:56 PM
RE: Philco Model 20 Lowboy - by morzh - 05-05-2017, 10:06 PM
RE: Philco Model 20 Lowboy - by Steve Davis - 05-05-2017, 11:39 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-06-2017, 11:05 AM
RE: Philco Model 20 Lowboy - by jcassity - 05-06-2017, 11:36 AM
RE: Philco Model 20 Lowboy - by morzh - 05-06-2017, 12:21 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-06-2017, 07:31 PM
RE: Philco Model 20 Lowboy - by Steve Davis - 05-06-2017, 11:01 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-07-2017, 04:30 PM
RE: Philco Model 20 Lowboy - by morzh - 05-07-2017, 06:23 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-13-2017, 04:45 PM
RE: Philco Model 20 Lowboy - by morzh - 05-13-2017, 04:54 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-13-2017, 06:09 PM
RE: Philco Model 20 Lowboy - by morzh - 05-13-2017, 06:44 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-13-2017, 07:01 PM
RE: Philco Model 20 Lowboy - by morzh - 05-13-2017, 07:39 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-14-2017, 12:31 AM
RE: Philco Model 20 Lowboy - by Radioroslyn - 05-14-2017, 07:55 AM
RE: Philco Model 20 Lowboy - by morzh - 05-14-2017, 10:41 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-14-2017, 11:57 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-15-2017, 09:07 PM
RE: Philco Model 20 Lowboy - by morzh - 05-15-2017, 10:14 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 05-16-2017, 01:11 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-18-2017, 11:09 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 06-19-2017, 12:56 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-19-2017, 10:05 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-19-2017, 09:42 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 06-19-2017, 10:18 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-20-2017, 11:39 AM
RE: Philco Model 20 Lowboy - by Radioroslyn - 06-20-2017, 12:45 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-20-2017, 09:02 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 06-20-2017, 11:26 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 06-21-2017, 02:08 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-01-2017, 04:15 PM
RE: Philco Model 20 Lowboy - by KCMike - 07-01-2017, 05:35 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 07-01-2017, 08:56 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-01-2017, 11:17 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 07-02-2017, 12:28 AM
RE: Philco Model 20 Lowboy - by morzh - 07-02-2017, 08:38 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-02-2017, 11:11 AM
RE: Philco Model 20 Lowboy - by morzh - 07-02-2017, 01:20 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-02-2017, 03:38 PM
RE: Philco Model 20 Lowboy - by Ron Ramirez - 07-02-2017, 06:53 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-02-2017, 08:20 PM
RE: Philco Model 20 Lowboy - by morzh - 07-02-2017, 10:40 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-03-2017, 10:40 AM
RE: Philco Model 20 Lowboy - by morzh - 07-03-2017, 10:52 AM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-03-2017, 02:25 PM
RE: Philco Model 20 Lowboy - by Radioroslyn - 07-03-2017, 09:38 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-04-2017, 02:30 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-10-2017, 09:26 PM
RE: Philco Model 20 Lowboy - by morzh - 07-10-2017, 09:39 PM
RE: Philco Model 20 Lowboy - by GarySP - 07-10-2017, 09:40 PM
RE: Philco Model 20 Lowboy - by morzh - 07-10-2017, 09:41 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-10-2017, 09:43 PM
RE: Philco Model 20 Lowboy - by morzh - 07-10-2017, 10:02 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-10-2017, 10:08 PM
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-14-2017, 01:29 PM
RE: Philco Model 20 Lowboy - by morzh - 07-14-2017, 05:12 PM
RE: Philco Model 20 Lowboy - by Steve Davis - 07-15-2017, 10:37 AM
Users browsing this thread: 27 Guest(s)
91H Code 126 Restore
There are currently 4902 online users. [Complete List]
» 1 Member(s) | 4901 Guest(s)
