1933-34 Philco 89B Restoration
Yeah, the very first tone control simply would not work.....that is, as a control, as shorting out 0.15uF in series with 0.01uF will change the capacitance from 10nF to 9.4nF which would be barely noticeable and is less than the tolerance of the caps itself.
RE: Philco 89 Capacitor Question - by morzh - 05-18-2017, 02:18 PM
RE: Philco 89 Capacitor Question - by Ron Ramirez - 05-18-2017, 03:07 PM
RE: Philco 89 Capacitor Question - by morzh - 05-18-2017, 03:31 PM
RE: 1933-34 Philco 89B Restoration - by morzh - 11-06-2017, 10:13 AM
RE: 1933-34 Philco 89B Restoration - by morzh - 01-16-2018, 02:21 PM
The speaker table error?
Philco 70 antenna lead
