Philco 60 Oscillator with a Weird Problem
If you see corrosion, remove the winding and redo.
RE: Philco 60 Oscillator with a Weird Problem - by morzh - 05-19-2017, 09:26 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4870 online users. [Complete List]
» 1 Member(s) | 4869 Guest(s)
