Heathkit Cap Tester C-3
Pull out the 1626. Solder in a 1N4007. Banded end to pin 8 other end to pin 3. This will replace your 1626 that you said was shorted. That might be what is causing the eye to flicker. Also check the 1M resistor on the back of the eye tube, that's where it's get it's HV to light the target (eye tube screen).
Heathkit Cap Tester C-3 - by vecher - 05-19-2017, 11:56 PM
RE: Heathkit Cap Tester C-3 - by Radioroslyn - 05-20-2017, 12:19 AM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 10:31 AM
RE: Heathkit Cap Tester C-3 - by morzh - 05-20-2017, 10:52 AM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 11:01 AM
RE: Heathkit Cap Tester C-3 - by Radioroslyn - 05-20-2017, 11:18 AM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 12:27 PM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 12:43 PM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 12:56 PM
RE: Heathkit Cap Tester C-3 - by morzh - 05-20-2017, 01:15 PM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 02:56 PM
RE: Heathkit Cap Tester C-3 - by Radioroslyn - 05-20-2017, 06:39 PM
RE: Heathkit Cap Tester C-3 - by vecher - 05-20-2017, 08:06 PM
RE: Heathkit Cap Tester C-3 - by Radioroslyn - 05-20-2017, 09:14 PM
RE: Heathkit Cap Tester C-3 - by vecher - 05-30-2017, 11:59 PM
RE: Heathkit Cap Tester C-3 - by vecher - 06-03-2017, 12:47 AM
RE: Heathkit Cap Tester C-3 - by Eliot Ness - 06-03-2017, 08:32 AM
RE: Heathkit Cap Tester C-3 - by vecher - 06-03-2017, 10:32 PM
RE: Heathkit Cap Tester C-3 - by Eliot Ness - 06-04-2017, 09:24 AM
RE: Heathkit Cap Tester C-3 - by vecher - 06-04-2017, 09:59 AM
RE: Heathkit Cap Tester C-3 - by Eliot Ness - 06-04-2017, 11:47 AM
RE: Heathkit Cap Tester C-3 - by vecher - 06-04-2017, 11:51 AM
RE: Heathkit Cap Tester C-3 - by vecher - 06-04-2017, 11:53 AM
RE: Heathkit Cap Tester C-3 - by Eliot Ness - 06-04-2017, 12:03 PM
RE: Heathkit Cap Tester C-3 - by vecher - 06-04-2017, 05:26 PM
RE: Heathkit Cap Tester C-3 - by vecher - 06-04-2017, 08:51 PM
RE: Heathkit Cap Tester C-3 - by Eliot Ness - 06-05-2017, 08:05 AM
RE: Heathkit Cap Tester C-3 - by TV MAN - 06-08-2017, 07:39 AM
Eico 232 VTVM Schematic
There are currently 6593 online users. [Complete List]
» 3 Member(s) | 6590 Guest(s)
