FStephenMasek's Philco 112 cabinet restoration
It is coming along well.  I cleaned-up the cabinet with lacquer thinner today, did some light sanding, then applied a wash of Pecan stain to get the color even (the Sentinel 104 went through the same process).
 [Image: http://i269.photobucket.com/albums/jj77/...tained.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
RE: FStephenMasek's Philco 112 restoration - by FStephenMasek - 05-20-2017, 11:23 PM
Philco 91 Tuning Condenser
There are currently 8082 online users. [Complete List]
» 2 Member(s) | 8080 Guest(s)
