Newbee advise
You can also go to Nostalgia air for schematics. YOULL BE GETTING MORE HIT FROM BETTER ADVISERS.
Newbee advise - by TimC - 01-21-2010, 06:43 PM
Re: Newbee advise - by denver - 01-21-2010, 07:32 PM
Re: Newbee advise - by denver - 01-21-2010, 09:09 PM
Re: Newbee advise - by 7estatdef - 01-21-2010, 09:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
