Need help re: restoration of a 41-100
Hmmm... too many questions at once? A fair amount of views but no replies....
Just knowing the kind of black paint to use on these kinds of restorations would be a big step in the right direction.
Thanks again for any help or advice offered...
Need help re: restoration of a 41-100 - by Guest - 01-15-2010, 06:08 PM
Re: Need help re: restoration of a 41-100 - by Guest - 01-22-2010, 08:46 AM
Re: Need help re: restoration of a 41-100 - by Guest - 01-22-2010, 11:17 AM
There are currently 10004 online users. [Complete List]
» 1 Member(s) | 10003 Guest(s)
