Zenith 9S54
Hi Adam. I'm adding a schematic link to your chassis to help anyone looking to answer your questions.
http://www.nostalgiaair.org/Resources/465/M0025465.htm
Zenith 9S54 - by adamrobertg - 05-24-2017, 02:54 PM
RE: Zenith 9S54 - by KCMike - 05-24-2017, 03:13 PM
RE: Zenith 9S54 - by Arran - 05-28-2017, 02:40 AM
RE: Zenith 9S54 - by adamrobertg - 05-30-2017, 09:51 PM
RE: Zenith 9S54 - by morzh - 05-30-2017, 10:55 PM
RE: Zenith 9S54 - by Arran - 05-31-2017, 02:55 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
