Alignment Procedure for 40-180
Thanks for the tips. I ordered a set of documentation from Chuck S. over at the Philco Repair Bench to go along with the docs Terry referenced.
I'm hoping to get the tubes ordered this week along with a set of new buttons. I'll be getting new caps as well.
What technique did you use to clean the contacts? I was going to use tuner cleaner then some WD-40.
Alignment Procedure for 40-180 - by Guest - 01-10-2006, 12:44 PM
[No subject] - by Terry Burns - 01-10-2006, 08:33 PM
[No subject] - by Ron Ramirez - 01-10-2006, 08:46 PM
40-180 Restoration - by Guest - 01-18-2006, 01:30 PM
[No subject] - by Ron Ramirez - 01-18-2006, 01:57 PM
[No subject] - by Guest - 01-19-2006, 06:04 PM
