89 oscillator check
Thank you!
89 oscillator check - by baspas - 01-22-2010, 11:22 AM
Re: 89 oscillator check - by baspas - 01-22-2010, 11:55 AM
Re: 89 oscillator check - by Carl Travis - 01-22-2010, 06:40 PM
Re: 89 oscillator check - by 7estatdef - 01-22-2010, 06:54 PM
Re: 89 oscillator check - by baspas - 01-23-2010, 02:14 PM
Re: 89 oscillator check - by 7estatdef - 01-23-2010, 09:37 PM
Re: 89 oscillator check - by baspas - 01-23-2010, 11:15 PM
Re: 89 oscillator check - by Ron Ramirez - 01-25-2010, 08:42 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
