Zenith 9S54
Mike is right, the parts list says that the choke is 1 millihenry (not 10 mh), which means that you can still find a replacement if you need to, but I would check that antenna coil primary too. I think the choke was intended as a wave trap, if it is burned out hopefully it acted as a fuse and saved the antenna coil primary from burning up as well since it connected closed to ground.
Zenith 9S54 - by adamrobertg - 05-24-2017, 02:54 PM
RE: Zenith 9S54 - by KCMike - 05-24-2017, 03:13 PM
RE: Zenith 9S54 - by Arran - 05-28-2017, 02:40 AM
RE: Zenith 9S54 - by adamrobertg - 05-30-2017, 09:51 PM
RE: Zenith 9S54 - by morzh - 05-30-2017, 10:55 PM
RE: Zenith 9S54 - by Arran - 05-31-2017, 02:55 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
