201x power transformer
On this set most of the filters sit at 250ohms above the chaiss.
201x power transformer - by garyh1 - 01-23-2010, 05:08 PM
Re: 201x power transformer - by garyh1 - 01-23-2010, 09:56 PM
Re: 201x power transformer - by 7estatdef - 01-24-2010, 08:29 AM
Re: 201x power transformer - by Alan Douglas - 01-24-2010, 02:49 PM
Re: 201x power transformer - by garyh1 - 01-24-2010, 04:22 PM
Re: 201x power transformer - by codefox1 - 01-24-2010, 04:30 PM
Re: 201x power transformer - by garyh1 - 01-24-2010, 05:36 PM
Re: 201x power transformer - by codefox1 - 01-24-2010, 06:07 PM
Re: 201x power transformer - by garyh1 - 01-24-2010, 06:39 PM
Re: 201x power transformer - by 7estatdef - 01-24-2010, 08:48 PM
Re: 201x power transformer - by Ron Ramirez - 01-25-2010, 08:36 AM
Re: 201x power transformer - by garyh1 - 01-25-2010, 03:28 PM
Re: 201x power transformer - by Ron Ramirez - 01-25-2010, 04:00 PM
Re: 201x power transformer - by garyh1 - 01-25-2010, 05:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
