Spring for vernier for 37-610T
Hi Steve
Looks like you may have to find a junker set to acquire the parts you need. Any 37-610, 37-611, 37-620, 37-623, 37-623, 37-630 or 37-640 should have that same dial drive. (The 37-61 and 37-89 drive might also work but I am not sure about those.) Also equivalent 1938 models. Or, if you carefully disassemble the drive from one of the above models, you could find out what type of spring and ball bearing you need.
I do not currently own any 1937 models or junkers, sorry.
Spring for vernier for 37-610T - by Steve D - 01-19-2010, 10:11 AM
Re: Spring for vernier for 37-610T - by Ron Ramirez - 01-25-2010, 08:24 AM
Re: Spring for vernier for 37-610T - by Steve D - 01-26-2010, 01:43 PM
Re: Spring for vernier for 37-610T - by Steve D - 01-26-2010, 06:34 PM
Re: Spring for vernier for 37-610T - by timh - 11-28-2010, 04:52 PM
Re: Spring for vernier for 37-610T - by TA Forbes - 12-03-2010, 11:11 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3147 online users. [Complete List]
» 2 Member(s) | 3145 Guest(s)
