Zenith 4-T-51
I pulled the chassis and, other than being very gummed up, the pot seemed fine. It basically uses a pressed in shaft to work the control pot, which is odd. After several doses of control cleaner to loosen it up, I was able to press the shaft back in tight enough to work for off-on and volume functions with no issues as long as I don't go wild with it. Radio passed the transformer test and actually pulled in a few stations at low power on the bulbs. All good signs! Icon_smile There are quite a few capacitors crammed under that little chassis though! Almost an un-Zenith like amount!
Zenith 4-T-51 - by Jayce - 06-03-2017, 07:11 PM
RE: Zenith 4-T-51 - by OldRestorer - 06-03-2017, 07:41 PM
RE: Zenith 4-T-51 - by Eliot Ness - 06-04-2017, 09:12 AM
RE: Zenith 4-T-51 - by Jayce - 06-04-2017, 12:42 PM
RE: Zenith 4-T-51 - by Eliot Ness - 06-04-2017, 05:10 PM
RE: Zenith 4-T-51 - by Jayce - 06-04-2017, 06:48 PM
RE: Zenith 4-T-51 - by Eliot Ness - 06-06-2017, 09:36 PM
RE: Zenith 4-T-51 - by Jayce - 06-06-2017, 09:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
