GE 50 Clock Radio
Well first off your little GE 50 doesn't have an IF adjustment as it isn't a superhet. It's a TRF set with one RF amp a Detector and two audio stages. Your right that it never had a loop. It had a small roll of wire that was to be use as a antenna. I had one years ago. Cute but not a very good performer at all.
GE 50 Clock Radio - by g8wayg8r - 11-30-2009, 01:41 AM
Re: GE 50 Clock Radio - by gary rabbitt - 12-11-2009, 02:57 PM
Re: GE 50 Clock Radio - by g8wayg8r - 12-28-2009, 01:19 AM
Re: GE 50 Clock Radio - by g8wayg8r - 01-25-2010, 12:09 AM
Re: GE 50 Clock Radio - by 7estatdef - 01-25-2010, 06:16 PM
Re: GE 50 Clock Radio - by g8wayg8r - 01-31-2010, 08:51 PM
There are currently 9018 online users. [Complete List]
» 1 Member(s) | 9017 Guest(s)
