Philco model 610 rebuild - by Tim P.
#61
OK, you gotta go and scratch that itch! Let's fire it up!
I can barely wait to fire up mine.
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by morzh - 06-05-2017, 08:17 AM
Users browsing this thread: 20 Guest(s)
The speaker table error?
Philco 70 antenna lead
