RP-3 no range
I just finished replacing caps,installing the rebuilt cartrige in my RP-3. Just to find out it has to sit no more then 2 feet from a radio to work. I tested the tubes (they're good), checked resistor resistance(w/in specs), played with the tuning adjustment and doubled checked connections and antenna. From what I read the range should be up to 25 feet or was this a marketing ploy. Any ideas! Thanks, Richard
RP-3 no range - by rjm - 01-18-2006, 09:50 PM
RP-3 - by Doug Houston - 01-19-2006, 05:48 PM
[No subject] - by rjm - 01-19-2006, 06:38 PM
[No subject] - by Doug Houston - 01-20-2006, 02:45 PM
[No subject] - by rjm - 01-20-2006, 09:53 PM
42 RP-2 - by panther - 01-26-2006, 11:13 PM
There are currently 10775 online users. [Complete List]
» 2 Member(s) | 10773 Guest(s)
