GE H-632U
Ok Do you have the + side of the filter caps connect to R-13 and the - side connected to the off/on switch? As Mike suggested try a new 25L6 and also a25L6 (may have a heater to cathode short).
GE H-632U - by vecher - 06-07-2017, 04:11 PM
RE: GE H-632U - by morzh - 06-07-2017, 04:56 PM
RE: GE H-632U - by vecher - 06-07-2017, 04:58 PM
RE: GE H-632U - by Radioroslyn - 06-07-2017, 06:44 PM
RE: GE H-632U - by vecher - 06-07-2017, 08:29 PM
RE: GE H-632U - by Radioroslyn - 06-08-2017, 02:25 AM
RE: GE H-632U - by vecher - 06-08-2017, 09:41 AM
RE: GE H-632U - by Radioroslyn - 06-08-2017, 03:02 PM
RE: GE H-632U - by morzh - 06-08-2017, 03:31 PM
RE: GE H-632U - by morzh - 06-08-2017, 03:42 PM
RE: GE H-632U - by vecher - 06-08-2017, 07:22 PM
RE: GE H-632U - by vecher - 06-09-2017, 03:34 PM
RE: GE H-632U - by morzh - 06-09-2017, 05:01 PM
RE: GE H-632U - by vecher - 06-10-2017, 12:14 AM
RE: GE H-632U - by Radioroslyn - 06-10-2017, 02:45 AM
RE: GE H-632U - by RodB - 06-10-2017, 05:00 PM
RE: GE H-632U - by vecher - 06-10-2017, 11:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6094 online users. [Complete List]
» 1 Member(s) | 6093 Guest(s)
