GE H-632U
Kinda like it is here:
http://www.nostalgiaair.org/pagesbymodel...007442.pdf
GE H-632U - by vecher - 06-07-2017, 04:11 PM
RE: GE H-632U - by morzh - 06-07-2017, 04:56 PM
RE: GE H-632U - by vecher - 06-07-2017, 04:58 PM
RE: GE H-632U - by Radioroslyn - 06-07-2017, 06:44 PM
RE: GE H-632U - by vecher - 06-07-2017, 08:29 PM
RE: GE H-632U - by Radioroslyn - 06-08-2017, 02:25 AM
RE: GE H-632U - by vecher - 06-08-2017, 09:41 AM
RE: GE H-632U - by Radioroslyn - 06-08-2017, 03:02 PM
RE: GE H-632U - by morzh - 06-08-2017, 03:31 PM
RE: GE H-632U - by morzh - 06-08-2017, 03:42 PM
RE: GE H-632U - by vecher - 06-08-2017, 07:22 PM
RE: GE H-632U - by vecher - 06-09-2017, 03:34 PM
RE: GE H-632U - by morzh - 06-09-2017, 05:01 PM
RE: GE H-632U - by vecher - 06-10-2017, 12:14 AM
RE: GE H-632U - by Radioroslyn - 06-10-2017, 02:45 AM
RE: GE H-632U - by RodB - 06-10-2017, 05:00 PM
RE: GE H-632U - by vecher - 06-10-2017, 11:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
