Philco model 610 rebuild - by Tim P.
#67
It is likely sun plus dial lght, as it likely was kept there due to being the favorite spot. I don't think it can be cleaned. As for dirt, yes, mineral spirits.
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by morzh - 06-08-2017, 11:22 PM
Users browsing this thread: 20 Guest(s)
The speaker table error?
Philco 70 antenna lead
