GE 7- 2885 Portable
I have had two issues on the Superadio I and II. By far the most common is that the AM RF amp transistor will fail. Easy to check for this... If you look at your tuner, you'll see that one lead from the antenna goes straight to one tuner section. Locate the larger of the other two sections and touch a screwdriver to that connection. If the radio gets louder, than the RF amp is your problem.
GE 7- 2885 Portable - by Paul Philco322 - 06-08-2017, 05:45 PM
RE: GE 7- 2885 Portable - by Kenneth F. Besso Jr. - 06-08-2017, 08:28 PM
RE: GE 7- 2885 Portable - by Paul Philco322 - 06-08-2017, 08:56 PM
RE: GE 7- 2885 Portable - by Jayce - 06-08-2017, 09:53 PM
RE: GE 7- 2885 Portable - by BrendaAnnD - 06-09-2017, 05:49 AM
RE: GE 7- 2885 Portable - by Paul Philco322 - 06-22-2017, 08:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
