Philco model 610 rebuild - by Tim P.
#68
I learned that one the hard way. It was a 19, it had me stumped for a week before I stumbled onto the cause.
M R Radios   C M Tubes
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by Steve Davis - 06-09-2017, 11:06 PM
The speaker table error?
Philco 70 antenna lead
