Model 89 RF stage
If your RF amp wasn't working your symptoms would be poor reception at the ant post and grid cap of the rf amp, signal would be good at the mixer grid cap. I'm thinking that you've got a weak mixer, IF amp tube , or alignment issue if the plate, screen, and cathode voltage are correct. Oh also have a look at the bandswitch contacts are clean and making good connection.
Model 89 RF stage - by RadioDR401 - 06-10-2017, 03:49 PM
RE: Model 89 RF stage - by Radioroslyn - 06-10-2017, 09:03 PM
RE: Model 89 RF stage - by RadioDR401 - 06-11-2017, 05:38 PM
RE: Model 89 RF stage - by RadioDR401 - 06-17-2017, 08:32 PM
RE: Model 89 RF stage - by Radioroslyn - 06-17-2017, 09:24 PM
RE: Model 89 RF stage - by RadioDR401 - 07-17-2017, 05:55 PM
The speaker table error?
Philco 70 antenna lead
