Philco 38-690 electronics restoration.
#64
Well, it's official: need to rewind two transformers.
The Output and the Interstage. Both have bad primaries.
I think I'll bother Heyboyer.
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by morzh - 06-11-2017, 04:32 PM
Users browsing this thread: 35 Guest(s)
The speaker table error?
Philco 70 antenna lead
