Model 89 RF stage
Thanks for the tips!  I also hit upon another idea to test the stage gain.  I metered the AVC line with the antenna wire on the clip, then on the 44 grid and finally on the 77 grid.  The RF stage is definitely working since I got about -2.3 volts from a weak station with the antenna on the clip vs about -0.8 on the 77 grid.  The station sounds about the same but clearly the RF stage is working.  I'll try the IF stages next as you suggested.
Dave Thomas
Coatesville, PA
Model 89 RF stage - by RadioDR401 - 06-10-2017, 03:49 PM
RE: Model 89 RF stage - by Radioroslyn - 06-10-2017, 09:03 PM
RE: Model 89 RF stage - by RadioDR401 - 06-11-2017, 05:38 PM
RE: Model 89 RF stage - by RadioDR401 - 06-17-2017, 08:32 PM
RE: Model 89 RF stage - by Radioroslyn - 06-17-2017, 09:24 PM
RE: Model 89 RF stage - by RadioDR401 - 07-17-2017, 05:55 PM
The speaker table error?
Philco 70 antenna lead
