Philco 38-690 electronics restoration.
Threads: 569
Joe,
It is super-kind of you to offer me that.
If it did, I'd decline as I have two spare chassis for 37-116 and it is likely at least one of them is good
But sadly, no, it won't fit as 37-116 has a simple interstage to drive two 6B4 or 6A5 and no tweeter output winding.
Not only that but to drive 6L6 you need different turn ratio from 6B4 anyway, this is why even 37-116 and 38-116 transformers are not interchangeable
Thanks very much anyway.
Mike.
RE: Philco 38-690 electronics restoration. - by morzh - 06-12-2017, 03:03 PM
Users browsing this thread: 34 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
