Westinghoue model 512
Wow, that looks great Dan! That's a beautiful radio now that you've got it cleaned up!
-Rodney
Westinghoue model 512 - by Dan Walker - 06-14-2017, 11:32 AM
RE: Westinghoue model 512 - by VntgRads - 06-14-2017, 11:49 AM
RE: Westinghoue model 512 - by Eliot Ness - 06-14-2017, 12:03 PM
RE: Westinghoue model 512 - by TV MAN - 06-14-2017, 01:29 PM
RE: Westinghoue model 512 - by palegreenthumb - 06-14-2017, 10:36 PM
RE: Westinghoue model 512 - by Dan Walker - 06-15-2017, 08:15 AM
RE: Westinghoue model 512 - by klondike98 - 06-15-2017, 10:37 AM
RE: Westinghoue model 512 - by KCMike - 06-15-2017, 02:42 PM
RE: Westinghoue model 512 - by Eliot Ness - 06-15-2017, 09:58 PM
RE: Westinghoue model 512 - by morzh - 06-15-2017, 10:31 PM
RE: Westinghoue model 512 - by Arran - 06-16-2017, 01:30 AM
RE: Westinghoue model 512 - by Dan Walker - 06-16-2017, 10:28 AM
RE: Westinghoue model 512 - by Arran - 06-23-2017, 12:57 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
