Westinghoue model 512
Dan;
  I think that you placed the wrong knobs on your Westinghouse, the before picture shows the correct ones, the later ones show it with RCA/Canadian G.E knobs from the 1940s. I also have a Canadian Westinghouse model 512 in the project pile, it's a 512A
to be exact, models 512 X and 512X were console models, and the knobs are more domed like the knobs in the before photo. The 512A is a 1936 model, the 527A is a 1937 model which is similar but only has two bands and a more rectangular dial. In any event I think that the cabinet on my model 512A is a little different, I'm not sure whether it has the contrasting bands of veneer near the ends like yours has. The knobs on your model 683A are correct, Westinghouse made a series of sets using those concentric knobs much like the ones early RCA TV sets used between 1940 and 1949. Canadian Westinghouse's radio factory was based in Hamilton, Ontario, and as such was within driving distance to a number of furniture companies in Kitchener, Stratford, and Woodstock, so that probably explains the fancy cabinets they used.
Westinghoue model 512 - by Dan Walker - 06-14-2017, 11:32 AM
RE: Westinghoue model 512 - by VntgRads - 06-14-2017, 11:49 AM
RE: Westinghoue model 512 - by Eliot Ness - 06-14-2017, 12:03 PM
RE: Westinghoue model 512 - by TV MAN - 06-14-2017, 01:29 PM
RE: Westinghoue model 512 - by palegreenthumb - 06-14-2017, 10:36 PM
RE: Westinghoue model 512 - by Dan Walker - 06-15-2017, 08:15 AM
RE: Westinghoue model 512 - by klondike98 - 06-15-2017, 10:37 AM
RE: Westinghoue model 512 - by KCMike - 06-15-2017, 02:42 PM
RE: Westinghoue model 512 - by Eliot Ness - 06-15-2017, 09:58 PM
RE: Westinghoue model 512 - by morzh - 06-15-2017, 10:31 PM
RE: Westinghoue model 512 - by Arran - 06-16-2017, 01:30 AM
RE: Westinghoue model 512 - by Dan Walker - 06-16-2017, 10:28 AM
RE: Westinghoue model 512 - by Arran - 06-23-2017, 12:57 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6500 online users. [Complete List]
» 1 Member(s) | 6499 Guest(s)
