Eico Model 315 SG
YUP.. OK here is a picture of the input ( Grid) of the 6SL7 Pin 1)
[Image: http://i292.photobucket.com/albums/mm38/...2pi2vu.jpg]
Here is next picture measured at ( Cathode Pin 3 6SL7) NOTE: I also measured at C5 Same as before C5..
[Image: http://i292.photobucket.com/albums/mm38/...hquxny.jpg]
Same scale on both..
1ST Not a sine wave 2nd output should be much greater than input??? The 6SL7 tests good on tube tester)
Am I measuring at the right places?
Skip..
PS I will do a complete Recap But everything I measured so far looks OK..
Eico Model 315 SG - by vecher - 06-15-2017, 11:58 PM
RE: Eico Model 315 SG - by Radioroslyn - 06-16-2017, 12:48 AM
RE: Eico Model 315 SG - by vecher - 06-16-2017, 04:51 PM
RE: Eico Model 315 SG - by vecher - 06-16-2017, 07:19 PM
RE: Eico Model 315 SG - by Eliot Ness - 06-16-2017, 09:49 PM
RE: Eico Model 315 SG - by vecher - 06-16-2017, 10:45 PM
RE: Eico Model 315 SG - by Radioroslyn - 06-16-2017, 10:54 PM
RE: Eico Model 315 SG - by vecher - 06-16-2017, 10:59 PM
RE: Eico Model 315 SG - by vecher - 06-19-2017, 12:31 AM
RE: Eico Model 315 SG - by vecher - 06-22-2017, 11:15 PM
RE: Eico Model 315 SG - by Radioroslyn - 06-23-2017, 01:37 AM
RE: Eico Model 315 SG - by vecher - 06-23-2017, 11:03 PM
RE: Eico Model 315 SG - by Radioroslyn - 06-23-2017, 11:51 PM
RE: Eico Model 315 SG - by vecher - 06-24-2017, 12:33 AM
RE: Eico Model 315 SG - by vecher - 06-24-2017, 09:37 PM
Eico 232 VTVM Schematic
There are currently 5588 online users. [Complete List]
» 2 Member(s) | 5586 Guest(s)
