201x 4 mfd can restuff
It looks that way, but you'll have to trace out the circuit against the schematic to be sure. It's been years since I looked at this chassis, but according to notes I made on the schematic, the 1µF all the way over to the right, connected to the speaker field, isn't in can 29. It must be somewhere, and the can with the 4µF is as likely a place as any. Especially if the can is marked 1 and 4.
201x 4 mfd can restuff - by garyh1 - 01-28-2010, 12:39 AM
Re: 201x 4 mfd can restuff - by Alan Douglas - 01-29-2010, 11:41 PM
Re: 201x 4 mfd can restuff - by garyh1 - 01-30-2010, 11:36 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
