Grandfather clock radio
(06-20-2017, 11:33 PM)Radioroslyn Wrote:  Hmm that's interesting. At 1st I thought it might be a Columaire but the pic I saw had the radio knobs on the right side not on the front.
There are two versions Terry, the bigger one has larger chassis' and controls on the side, while this one has a single smaller chassis and controls on the front.
[Image: http://img.usaudiomart.com/uploads/large...rigina.jpg]
Grandfather clock radio - by NostalgiaRadioTime - 06-20-2017, 07:37 PM
RE: Grandfather clock radio - by Radioroslyn - 06-20-2017, 08:14 PM
RE: Grandfather clock radio - by WallaceRoger - 06-20-2017, 09:24 PM
RE: Grandfather clock radio - by Radioroslyn - 06-20-2017, 11:33 PM
RE: Grandfather clock radio - by Eliot Ness - 06-21-2017, 12:00 PM
RE: Grandfather clock radio - by Radioroslyn - 06-21-2017, 01:39 PM
RE: Grandfather clock radio - by sam - 06-21-2017, 07:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
