Philco 38-690 electronics restoration.
#85
The interstage has to be CLASS A, as it is one pentode 6F6 driving the primary of the transformer which in turn drives the 6L6 pushpull and the tweeters directly​.
As for the tire valve, no it ain't cheap, it is the whole assembly for the pressure sensor. Aftermarket is $90 apiece, which is what I did, otherwise OEM in my dealership is $200 apiece.
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by morzh - 07-01-2017, 11:01 AM
Users browsing this thread: 39 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 6440 online users. [Complete List]
» 1 Member(s) | 6439 Guest(s)
