need help on philco 37-600
need to know what part replaces this on a philco model 37-600 it has 3 leads coming out of it. Im leaving the can just need to stuff can with proper replacement. I think leads are positive, negative and ground but not sure. any help is greatly appreciated.
philco part 30-2149A 8-4 mf 450 volts
here is pic of can
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
need help on philco 37-600 - by Guest - 02-03-2010, 10:36 AM
Re: need help on philco 37-600 - by Carl Travis - 02-03-2010, 01:11 PM
Re: need help on philco 37-600 - by Guest - 02-03-2010, 02:10 PM
Re: need help on philco 37-600 - by 7estatdef - 02-03-2010, 07:04 PM
New member
Philco 630csx power cord
New member
There are currently 3994 online users. [Complete List]
» 1 Member(s) | 3993 Guest(s)
