  • 1 Vote(s) - 5 Average
Philco 89 veneer missing
Well I'm finally ready to finish the cabinet for my 89 so I started with the front panel.  I used lacquer thinner and steel wool to remove the old toner and although it worked well it seems a little darker than I expected and definitely darker than the new arch that Steve made for me.  I'm wondering if the thinner turned the old lacquer into a sort of stain that darkened the veneer.  Should I just leave it alone and continue finishing or sand it a bit.  I'm worried about taking off too much of the old veneer.  Any suggestions?
Dave Thomas
Coatesville, PA
Philco 89 veneer missing - by RadioDR401 - 03-07-2017, 09:00 PM
RE: Philco 89 veneer missing - by John Bartley - 03-08-2017, 08:12 AM
RE: Philco 89 veneer missing - by Steve Davis - 03-08-2017, 10:29 AM
RE: Philco 89 veneer missing - by Radioroslyn - 03-10-2017, 09:40 PM
RE: Philco 89 veneer missing - by Arran - 03-13-2017, 01:54 AM
RE: Philco 89 veneer missing - by Steve Davis - 03-13-2017, 10:29 PM
RE: Philco 89 veneer missing - by Arran - 03-13-2017, 10:43 PM
RE: Philco 89 veneer missing - by RadioDR401 - 03-14-2017, 11:42 AM
RE: Philco 89 veneer missing - by Steve Davis - 03-14-2017, 01:27 PM
RE: Philco 89 veneer missing - by Arran - 03-14-2017, 07:50 PM
RE: Philco 89 veneer missing - by RadioDR401 - 07-04-2017, 11:41 AM
RE: Philco 89 veneer missing - by Steve Davis - 07-04-2017, 02:07 PM
RE: Philco 89 veneer missing - by RadioDR401 - 07-05-2017, 04:28 PM
RE: Philco 89 veneer missing - by Phlogiston - 07-05-2017, 06:13 PM
RE: Philco 89 veneer missing - by RadioDR401 - 07-06-2017, 07:18 AM
RE: Philco 89 veneer missing - by Phlogiston - 07-06-2017, 10:33 AM
RE: Philco 89 veneer missing - by RadioDR401 - 08-29-2017, 12:40 PM
RE: Philco 89 veneer missing - by RadioDR401 - 09-09-2017, 03:33 PM
RE: Philco 89 veneer missing - by Phlogiston - 09-09-2017, 04:05 PM
RE: Philco 89 veneer missing - by Scott D - 09-09-2017, 05:15 PM
RE: Philco 89 veneer missing - by RadioDR401 - 03-05-2018, 05:09 PM
RE: Philco 89 veneer missing - by sdradioman - 03-05-2018, 10:07 PM
RE: Philco 89 veneer missing - by Radioroslyn - 03-05-2018, 11:46 PM
RE: Philco 89 veneer missing - by RadioDR401 - 03-06-2018, 10:49 AM
