Isolation Transformer Output
You are measuring the output voltage under no-load conditions. Put a radio (within current spec of the transformer) on it and re-measure.
Chuck
Isolation Transformer Output - by g8wayg8r - 02-04-2010, 10:12 PM
Re: Isolation Transformer Output - by Chuck Schwark - 02-05-2010, 10:50 AM
Re: Isolation Transformer Output - by g8wayg8r - 02-06-2010, 12:46 PM
Re: Isolation Transformer Output - by codefox1 - 02-06-2010, 02:07 PM
Re: Isolation Transformer Output - by radiomikee - 02-08-2010, 11:42 PM
Re: Isolation Transformer Output - by g8wayg8r - 02-09-2010, 02:01 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6085 online users. [Complete List]
» 1 Member(s) | 6084 Guest(s)
