Weller pencil iron
Didn't have any trouble getting out it unscrewed easily. But flux in the solder was eating up the copper(after 3 or4yrs). I had read that cheap folks would not reshape the tip by filing or grinding but would beat it w/a hammer thus saving the copper. But you can only beat it so much.
I tried a 10-24 steel and brass machine screws but too much heat lost. Don't conduct heat as well as copper.
Weller pencil iron - by Radioroslyn - 07-06-2017, 01:44 PM
RE: Weller pencil iron - by klondike98 - 07-06-2017, 02:48 PM
RE: Weller pencil iron - by morzh - 07-06-2017, 03:22 PM
RE: Weller pencil iron - by Radioroslyn - 07-06-2017, 03:53 PM
RE: Weller pencil iron - by morzh - 07-06-2017, 04:38 PM
RE: Weller pencil iron - by sam - 07-06-2017, 07:21 PM
RE: Weller pencil iron - by Radioroslyn - 07-06-2017, 07:31 PM
RE: Weller pencil iron - by Welder - 11-21-2017, 08:16 PM
RE: Weller pencil iron - by Radioroslyn - 11-21-2017, 10:30 PM
RE: Weller pencil iron - by radiohenry - 11-24-2017, 10:28 AM
RE: Weller pencil iron - by Ron Ramirez - 11-25-2017, 11:14 PM
RE: Weller pencil iron - by David - 11-27-2017, 07:08 PM
RE: Weller pencil iron - by WallaceRoger - 12-04-2017, 12:29 PM
RE: Weller pencil iron - by Kenneth F. Besso Jr. - 12-04-2017, 08:41 PM
RE: Weller pencil iron - by jcassity - 07-15-2018, 10:04 PM
RE: Weller pencil iron - by Arran - 07-16-2018, 05:08 AM
RE: Weller pencil iron - by Radioroslyn - 07-16-2018, 09:06 AM
RE: Weller pencil iron - by 35Z5 - 07-16-2018, 09:51 AM
RE: Weller pencil iron - by codefox1 - 07-16-2018, 03:16 PM
RE: Weller pencil iron - by Radioroslyn - 07-16-2018, 08:44 PM
There are currently 9611 online users. [Complete List]
» 1 Member(s) | 9610 Guest(s)
