Philco 41-280 code 121
Arran, yes, the output xfmr is rather small.
Gary,
I'll do my best to document all I will have done, though not sure how much it will be, as the wiring, unless I ruin it, is likely to stay. Nowto the recap - and it ain't gonna be much different from the one I have just done on the Hippo. Disembowel - restuff, ptetty much like gefillte fish Icon_smile
Just realized I am almost out of 0.047 uF tubulars - spent a ton between the 38-690 and the Hippo. Maybe two are left.
Philco 41-280 code 121 - by morzh - 07-05-2017, 08:22 PM
RE: Philco 41-280 code 121 - by Arran - 07-06-2017, 06:13 PM
RE: Philco 41-280 code 121 - by GarySP - 07-06-2017, 07:26 PM
RE: Philco 41-280 code 121 - by morzh - 07-06-2017, 07:49 PM
RE: Philco 41-280 code 121 - by morzh - 07-06-2017, 10:29 PM
RE: Philco 41-280 code 121 - by morzh - 07-06-2017, 10:36 PM
RE: Philco 41-280 code 121 - by morzh - 07-06-2017, 10:41 PM
RE: Philco 41-280 code 121 - by morzh - 07-08-2017, 07:23 PM
RE: Philco 41-280 code 121 - by GarySP - 07-08-2017, 11:12 PM
RE: Philco 41-280 code 121 - by morzh - 07-08-2017, 11:21 PM
RE: Philco 41-280 code 121 - by morzh - 07-09-2017, 01:56 PM
RE: Philco 41-280 code 121 - by Radioroslyn - 07-09-2017, 03:58 PM
RE: Philco 41-280 code 121 - by morzh - 07-09-2017, 04:48 PM
RE: Philco 41-280 code 121 - by KCMike - 07-09-2017, 05:16 PM
RE: Philco 41-280 code 121 - by morzh - 07-09-2017, 05:33 PM
RE: Philco 41-280 code 121 - by morzh - 07-09-2017, 05:44 PM
RE: Philco 41-280 code 121 - by GarySP - 07-10-2017, 08:08 PM
RE: Philco 41-280 code 121 - by GarySP - 07-10-2017, 08:49 PM
RE: Philco 41-280 code 121 - by morzh - 07-10-2017, 09:40 PM
RE: Philco 41-280 code 121 - by morzh - 07-22-2017, 09:43 PM
RE: Philco 41-280 code 121 - by 462ron - 07-23-2017, 11:43 AM
RE: Philco 41-280 code 121 - by morzh - 07-23-2017, 01:33 PM
RE: Philco 41-280 code 121 - by Radioroslyn - 07-23-2017, 02:17 PM
RE: Philco 41-280 code 121 - by morzh - 07-23-2017, 07:30 PM
RE: Philco 41-280 code 121 - by morzh - 07-26-2017, 06:34 PM
The speaker table error?
Philco 70 antenna lead
