Cracked veneer, any easy fix?
Here is a couple of pictures of one side that is affected. The other side has the same condition.
Thanks for any help.
Regards,
Kurt[attachment=0][attachment=1]
Cracked veneer, any easy fix? - by wu8v - 02-06-2010, 11:15 PM
Re: Cracked veneer, any easy fix? - by wu8v - 02-06-2010, 11:49 PM
Re: Cracked veneer, any easy fix? - by wu8v - 02-07-2010, 05:02 PM
Re: Cracked veneer, any easy fix? - by codefox1 - 02-07-2010, 06:10 PM
