Detrola 247 faulty Ballast, help me replace it
Here are a couple of pic's of this little jem.
[Image: http://i103.photobucket.com/albums/m140/...5_1074.jpg]
[Image: http://i103.photobucket.com/albums/m140/...7_1076.jpg]
[Image: http://i103.photobucket.com/albums/m140/...2_1081.jpg]
May look just another cheap old radio but it was my mother's childhood radio and I know she would get a kick out of hearing it play again. And can anyone figure out why the dial shows a mirror image of its' self below. There doesn't seem to be any difference, or am i missing something obvious.?
Re: Detrola 247 faulty Ballast, help me replace it - by Elrick - 02-07-2010, 01:05 AM
There are currently 9184 online users. [Complete List]
» 2 Member(s) | 9182 Guest(s)
