Signal generator
A simple two-tube job can be had for $20 or, during a Kutztown auction, $5.
This said, John F. Rider et all describes the "proper", lab type alignment, but, again, for a TRF set like 20 and such the tune-to-a-station type will do just fine and will yield as good a result as anything.
For a superhet alignment a generator is highly desirable.
Signal generator - by WallaceRoger - 07-11-2017, 11:17 AM
RE: Signal generator - by Radioroslyn - 07-11-2017, 11:45 AM
RE: Signal generator - by morzh - 07-11-2017, 11:49 AM
RE: Signal generator - by WallaceRoger - 07-11-2017, 12:25 PM
RE: Signal generator - by morzh - 07-11-2017, 12:33 PM
RE: Signal generator - by Radioroslyn - 07-11-2017, 01:02 PM
RE: Signal generator - by morzh - 07-11-2017, 01:14 PM
RE: Signal generator - by WallaceRoger - 10-02-2017, 03:03 PM
RE: Signal generator - by Radioroslyn - 10-02-2017, 09:19 PM
RE: Signal generator - by WallaceRoger - 10-02-2017, 11:05 PM
RE: Signal generator - by Ron Ramirez - 10-03-2017, 10:24 AM
RE: Signal generator - by morzh - 10-03-2017, 10:59 AM
RE: Signal generator - by WallaceRoger - 10-03-2017, 11:55 AM
RE: Signal generator - by Eliot Ness - 10-03-2017, 12:11 PM
RE: Signal generator - by morzh - 10-03-2017, 01:22 PM
RE: Signal generator - by WallaceRoger - 10-03-2017, 01:22 PM
Eico 232 VTVM Schematic
