Cracked veneer, any easy fix?
Thanks Ron,
I have worked on solid wood furniture and guitars for many years. This is my first major veneer project.
Modern waxes have been banned in my house for as long as I have been here. (they bring them home, I throw them away, pretty soon they get the message).
Thanks again and I will post progress reports when I get this thing moving, both electrically and cabinet wise.
Kurt
Cracked veneer, any easy fix? - by wu8v - 02-06-2010, 11:15 PM
Re: Cracked veneer, any easy fix? - by wu8v - 02-06-2010, 11:49 PM
Re: Cracked veneer, any easy fix? - by wu8v - 02-07-2010, 05:02 PM
Re: Cracked veneer, any easy fix? - by codefox1 - 02-07-2010, 06:10 PM
There are currently 9073 online users. [Complete List]
» 1 Member(s) | 9072 Guest(s)
