Model B1349 radio/phonograph
Hi and welcome,
Do you have the turn table out?? Post a pic of it's bottom side.
Model B1349 radio/phonograph - by glsilver - 07-12-2017, 05:28 PM
RE: Model B1349 radio/phonograph - by klondike98 - 07-12-2017, 06:53 PM
RE: Model B1349 radio/phonograph - by Radioroslyn - 07-12-2017, 09:47 PM
RE: Model B1349 radio/phonograph - by ODPILOT - 07-13-2017, 06:37 PM
RE: Model B1349 radio/phonograph - by glsilver - 07-14-2017, 01:16 PM
RE: Model B1349 radio/phonograph - by ODPILOT - 07-14-2017, 02:59 PM
The speaker table error?
Philco 70 antenna lead
