Philco 7170 AM/FM generator transformer
I replace with a transformer and now the rf works - 1.5 p/p output and is close to dial settings.
Audio oscillator doesn't oscillate. You mentioned playing with phasing - not sure exactly what you mean. help?
RE: Philco 7170 AM/FM generator transformer - by bakerm - 07-13-2017, 09:34 AM
