Threads: 20
City: Orland Park
State, Province, Country: Illiinois
One thing I do need to do is trim back and reattach the speaker plug. The cord just at the point it enters the plug is in kind of crappy shape after being twisted and moved around excessively by me.
What do you guys use to put the plug halves back together after you've drilled out the rivets? I'm worried pop rivets will crack the bakelite.
Greg
(This post was last modified: 07-14-2017, 01:29 PM by WallaceRoger.)
RE: Philco Model 20 Lowboy - by WallaceRoger - 07-14-2017, 01:29 PM
Users browsing this thread: 31 Guest(s)
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
There are currently 4977 online users. [Complete List] » 1 Member(s) | 4976 Guest(s)
