Philco 60 Warped Dial
Right. The rivets would be a problem, but I can leave the dial on the shaft and make a U-shaped press. If it'll stand up to the minimum heat to make it plastic--that's what I needed to know. If necessary, the rivets can be replaced with small nuts & bolts. Thanks.
Philco 60 Warped Dial - by Winky Dink - 07-14-2017, 01:18 AM
RE: Philco 60 Warped Dial - by Radioroslyn - 07-14-2017, 06:03 AM
RE: Philco 60 Warped Dial - by mcusi - 07-14-2017, 01:24 PM
RE: Philco 60 Warped Dial - by Winky Dink - 07-14-2017, 01:37 PM
RE: Philco 60 Warped Dial - by Radioroslyn - 07-14-2017, 05:30 PM
RE: Philco 60 Warped Dial - by Winky Dink - 07-15-2017, 12:33 AM
RE: Philco 60 Warped Dial - by Scott D - 08-17-2017, 10:55 AM
RE: Philco 60 Warped Dial - by Winky Dink - 12-09-2017, 01:37 AM
Eico 232 VTVM Schematic
There are currently 9592 online users. [Complete List]
» 1 Member(s) | 9591 Guest(s)
